506
Edit mode problem
I have a datagrid that could be in edit mode or not and this behavior changes dinamically by code.
I have a problem with a comboeditor. If the datagrid has the property AllowEdit = false the combobox will open if i click on the arrow and change the value. It remain close if I click on the item.
How can I disable this behavior?
Sacha
  • 17559
    Suggested Answer
    Hello Sacha,
    It has been a while since you have made your  post, in case you still need any support I will be glad to assist you on this. I suppose the other community members can benefit from this answer as well.  So I researched the issue you are describing and I am not able to reproduce the mentioned behavior. Please find the attached sample where I have XamComboEditor in one of the fields of XamDataGrid. If you set the AllowEdit property to true and click on the field the Drop down of the editor shows. If you set the AllowEdit to false, on click it remains closed and the arrow doesn't show in the field’s cells.
    If you still need any assistance on this issue or if I have misunderstood you in any way, please feel free to contact me.
