65
Problem in displaying data in XamDataGrid
   I have a trouble in displaying data in the XamdataGrid.The code shown below does not display any data in the grid.Can you please help me?
//xaml part
 <my:XamDataGrid Grid.Column="1" Margin="0,6,12,12" Name="xamDataGrid1"            FieldLayoutInitialized="FieldLayOut_CaseJournel" Grid.Row="1" >
            <my:XamDataGrid.FieldLayoutSettings>
                <my:FieldLayoutSettings AutoGenerateFields="False"></my:FieldLayoutSettings>
            </my:XamDataGrid.FieldLayoutSettings>
        </my:XamDataGrid>
//C# .NET
private void GridDisplay(string s )
                da = new OracleDataAdapter(s,conn);
                ds = new DataSet();
                da.Fill(ds);
                xamDataGrid1.DataSource = ds.Tables[0].DefaultView;
        private void OnWindowload(object sender, RoutedEventArgs e)
                OpenOracleConnection();
                string sql = "Select case.File_nr,court.court_name " +
                              "from case_journal,case,court,cstmr " +
                              "where case_journal.case_id=case.case_id " +
                              "AND case.court_id=court.court_id " +
                              "AND case.cstmr_id=cstmr.cstmr_id ";
                GridDisplay(sql);
private void FieldLayOut_CaseJournel(object sender, Infragistics.Windows.DataPresenter.Events.FieldLayoutInitializedEventArgs FieldEvent)
            Field FileNo = new Field();
            FileNo.Name = "File_nr";
            FileNo.Label = "File Number";
            Field CourtName = new Field();
            CourtName.Name = "court_name";
            CourtName.Label = "Court Name";
            FieldEvent.FieldLayout.Fields.Add(FileNo);
            FieldEvent.FieldLayout.Fields.Add(CourtName);
Shiffy
