I am an beginner in WPF and I want to set the background of the CellValuePresenter to transparent so that I ca see the background and not the rectangles.
I use the texteditor control to wrap the text. The xaml code is the following:
igDP:XamDataCarousel x:Name="XamDataCarousel1" Background="Transparent" GroupByAreaLocation="None" Margin="20" FontWeight="Bold" FontSize="15" CellContainerGenerationMode
="Recycle">
<igDP:XamDataCarousel.Resources
<Style TargetType="{x:Type igDP:CellValuePresenter}" x:Key
="WrapField">
<Setter Property
="Template">
<Setter.Value
<ControlTemplate TargetType="{x:Type igDP:CellValuePresenter
<igEditors:XamTextEditor Margin="{TemplateBinding Padding}"
Width="{TemplateBinding Width}"
Height="{TemplateBinding Height
VerticalScrollBarVisibility
="Auto"
Text="{Binding Content, RelativeSource={RelativeSource TemplatedParent
TextAlignment
="Center"
VerticalContentAlignment
HorizontalContentAlignment
TextWrapping
="Wrap"
Foreground
="#204F8A"
IsReadOnly
="True"
HorizontalAlignment="Stretch"
VerticalAlignment="Stretch" BorderThickness="0" Background
="Transparent">
<!--<igEditors:XamTextEditor.Background>
<ImageBrush ImageSource="Ressourcen\Box2.png" Stretch="Fill" />
</igEditors:XamTextEditor.Background>-->
</ControlTemplate
</Setter.Value
</Setter
<Setter Property="Background" Value
="Transparent"/>
</Style
</igDP:XamDataCarousel.Resources
<igDP:XamDataCarousel.FieldLayouts
<igDP:FieldLayout
<igDP:Field x:Uid="Name" Name
="Name">
<igDP:Field.Settings
<igDP:FieldSettings CellMinWidth="100" CellWidth
="360"
CellValuePresenterStyle="{StaticResource WrapField
</igDP:Field.Settings
</igDP:Field
</igDP:FieldLayout
</igDP:XamDataCarousel.FieldLayouts
<igDP:XamDataCarousel.ViewSettings
<igWindows:CarouselViewSettings ScalingEffectStopDirection="UseItemPath" UseScaling="True" ItemsPerPage="7" IsListContinuous="False"
IsNavigatorVisible="False" ItemPathVerticalAlignment="Stretch" ItemSize="170,70" ShouldAnimateItemsOnListChange="True"
HeightInInfiniteContainers="300" AutoScaleItemContentsToFit="True" ItemPathAutoPad="True" ItemPathHorizontalAlignment="Stretch"
ItemPathPadding
="20,0,20,120">
<igWindows:CarouselViewSettings.ScalingEffectStops
<igWindows:ScalingEffectStop Offset="0" Value
=".7" />
<igWindows:ScalingEffectStop Offset="0.5" Value
="1.5" />
<igWindows:ScalingEffectStop Offset="1" Value
</igWindows:CarouselViewSettings.ScalingEffectStops
</igDP:XamDataCarousel.ViewSettings
<igDP:XamDataCarousel.FieldSettings
<igDP:FieldSettings AllowEdit="False" AutoSizeOptions= "Label" CellClickAction="SelectRecord" LabelTextTrimming="CharacterEllipsis" LabelTextWrapping="WrapWithOverflow" CellContentAlignment="Default" CellMinHeight="100" LabelTextAlignment
="Center" />
</igDP:XamDataCarousel.FieldSettings
<igDP:XamDataCarousel.FieldLayoutSettings
<igDP:FieldLayoutSettings AutoGenerateFields="False" AllowAddNew="False" AllowDelete="False" AllowClipboardOperations
="Copy" />
</igDP:XamDataCarousel.FieldLayoutSettings
</igDP:XamDataCarousel>
So what do I have to chage or to set????
Thank you for your help
Michael
Hello Michael,
A similar highlight is caused by the CardBackground of template card view of the DataRecordPresenter.
You can turn this off by changing the color of this brush by using this code:
<LinearGradientBrush x:Key="{ComponentResourceKey {x:Type igDP:XamDataGrid}, CardBackground}" EndPoint="0,1" StartPoint="0,0">
<GradientStop Color="Transparent" Offset="0"/>
<GradientStop Color="Transparent" Offset="1"/>
</LinearGradientBrush>
