I currently use the xamDataGrid to display hierarchical data like xamFeatureBrowser -> xamDataGrid -> Layout and Behavior -> FieldSettings Overrides.Here i can only use the "Name"-Field for grouping the data.I want to be able to drag other (second-level) fields to the group by area so I can group by these fields, too (see image below). How can I do this?
thanks
From the screenshot I can see that you are using a version prior to 9.2. Your requirement is a new feature in the 9.2 release, so make sure you try it.
