I am trying to have a record seprator in my data grid which only seprator a set of records similar in record fixing but I dont want to fix my records while scrolling. I only want to have a seprator which distinguish my set of records for example I have 10 records I want to separate my records with a line 3 records in a set and a seprator 5 records then seprator 2 records and a seprator.
1
2
3
4
5
6
7
8
9
10
Any help ill be appriciated .
Thanks.
Hi Alex,
Thanks for reply, Well I am doing in the same way defining my datarecordpresenterstyle in xamdatagrid resources. But still the problem of relocation of fields persists. please add checkbox and slider control in your grid and dock from dockpanel and resize the widths of fields and then undock the grid back to dockpanel you ill find the error I am refering to.
Where have you defined the DataRecordPresenter style? It could be that when you undock the content pane the style is lost because the XDG will be placed in a floating content pane, which uses a different visual tree. I am attaching a sample project with this - try moving the style from the XDG's resources to the Window's or Grid's resources.
I would also suggest not to change the template with the trigger. Probably it would be better if you change a single property with a trigger instead of changing the whole template. You can see this covered in the sample as well.
Thanks for reply. Well Alex I cant provide the similar code sample because of shortage of time but I am sending you a screen shot of my grid. And I belive problem is because of DataRecord Presenter defined for the border given above. My grid's Autofit Mode is Default. this problem of relocation of column aries on all autofit options.
Can you provide us with a sample project that reproduces this and we will look into it?
Thanks for reply, yes it seems that its working, But I notice another problem in my datagrid I am composing different controls like checkbox and slider controls in each row. and this grid is hosted in a pane of xamdocmanager. I dont know when i undock this grid from dockmanager its both column change their position. Initially both are in start but while undocking my grid both goes to the end. Can you please also suggest wot could be the problem and its solution thanks.
