Is there a way to do an insert row, let me explain. I want to add a new row but not at the end or at the beginning, but between 2 existing row.Also from the same problem, if by mistake I added it at then end, is there a way to drag a row inside the grid (change order) to place it between 2 existing row.
Thank you in advance for taking the time to help me.
Martin.
how is it possible to change the order of the rows (records) by using the mouse? Do you have a sample project for this?
Thanks!
Gawain
Yes,
This time you can use the Insert(...) method of the Observablecollection to insert an item between two other.
The move works very well thank you.
But is it possible to get a insert row inside the xamDataGrid? (An add row between 2 existing row)
Is it possible to drag a row in the xamDataGrid so if it's the 3rd row I can drag it up and it falls between the first and the second row?
Martin,
When you are adding a new object, you can use the Insert method of your underlying source collection (for example ObservableCollection). You can also use Move method.
ObservableCollection<string> source = new ObservableCollection<string>();
source.Move(index1, index2);
