i´m testing the xamNumericEditor. I´m using MVVM. I will bind the value-property of xamNumericEdior to a property with value int32=4711 in my viewmodel. When the app is running and i delete the value in the view, in my viewmodel, the last value int32=4 is stored. Is that a bug?
best regards from Germany
Christian
The sample does no longer seem to apply, I can't find a property "EditorValue" to bind to.
This works for me, however:
<Style TargetType="{x:Type igEditors:ValueEditor}"> <Setter Property="ValueConstraint"> <Setter.Value> <igEditors:ValueConstraint Nullable="False" /> </Setter.Value> </Setter> <EventSetter Event="EditModeValidationError" Handler="EditModeValidationErrorHandler"/> </Style.Setters> </Style>
private void EditModeValidationErrorHandler(object sender, EditModeValidationErrorEventArgs e) { if (e.Editor.Value == null) { e.Handled = true; e.Editor.Value = 0; } }
This sounds like an issue that was recently reported and addressed in the latest hotfix for 9.2. Please try downloading the latest hotfix and see if you still get the problem.
Hi
I have some kind of performance problem, I'm working with MVVM, I have 15 xamNumericEditor controls on the screem with this constraint :
my:XamNumericEditor.ValueConstraint>
<my:ValueConstraint MinInclusive="0.00" MaxInclusive="100.00" />
</my:XamNumericEditor.ValueConstraint>
I retrive the values for each control from an object collection that it's shown in a xamDataGrid, but it takes a couple of seconds, however when I delete all the constraints it takes no time.
am I missing something ?
Hi Vlad,
that´s what i need!
Thank you very much!
Christian,
There is no property that is responsible for the default value and as I can see the revert value will return your last valid value and the retain value will return the last valid digit because of the PropertyChanged trigger. I suggest you to use a converter for the editor's Value instead, where you can check if the value is null and return 0. I'm attaching a sample so you can check it out.
