345
Trouble binding properties of the XamChart
I'm not sure what I am doing wrong here.  Could you please help me.  I'm trying to bind various properties of an XamChart and it seems to ignore the returned result.  Underneath is an example :
<igCA:Axis.Stripes>
      <igCA:Stripe Unit="{Binding Path=SelectedValue, Converter={StaticResource CrossingConverter}, ElementName=AccountComboBox, Mode=Default}"/>
</igCA:Axis.Stripes>
[ValueConversion(typeof(object), typeof(Double))]
public class CrossingConverter : IValueConverter {
      public object Convert(object value, Type targetType, object parameter, CultureInfo culture) {
if (value == null || ((Account)value).PortfolioAccounts == null)
return (Double)100;
else
return (Double)Math.Round(((Account)value).PortfolioAccounts.InitialValue, 0);
      public object ConvertBack(object value, Type targetType, object parameter, CultureInfo culture) {
return null;
The value converter code is getting called and returning a value, however whenever I look at the value stored in the Unit it is always 0.
Graeme
PS.  XamChart is looking like it will be a very good product.
  • 28496
    i tried this on my machine ... simplified in a few places... following is the complete solution.
     <Window x:Class="WpfApplication2.Window1"
    xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
    xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
    xmlns:igCA="clr-namespace:Infragistics.Windows.Chart;assembly=Infragistics3.Wpf.Chart.v7.2"
    xmlns:local="clr-namespace:WpfApplication2"
    Title="Window1" Height="300" Width="300">
    <Window.Resources>
    <local:CrossingConverter x:Key="CrossingConverter1" />
    </Window.Resources>
    <Canvas>
    <ComboBox x:Name="AccountComboBox" Width="100" Height="25" />
    <igCA:XamChart Width="250" Height="250" Canvas.Top="30">
    <igCA:XamChart.Axes>
    <igCA:Axis AxisType="PrimaryX">
    <igCA:Axis.Stripes>
    <igCA:Stripe Unit="{Binding Path=SelectedValue, Converter={StaticResource CrossingConverter1}, ElementName=AccountComboBox, Mode=Default}" />
    </igCA:Axis>
    </igCA:XamChart.Axes>
    </igCA:XamChart>
    </Canvas>
    </Window>
    using System;
    using System.Collections.Generic;
    using System.Globalization;
    using System.Windows.Data;
    using System.Windows;
    namespace WpfApplication2
    /// <summary>
    /// Interaction logic for Window1.xaml
    /// </summary>
    public partial class Window1 : Window
    public Window1()
    InitializeComponent();
    this.AccountComboBox.ItemsSource = new List<Account>
    new Account { Name = "John", Value = 1},
    new Account { Name = "Paul", Value = 2},
    new Account { Name = "George", Value = 3},new Account { Name = "Ringo", Value = 4}
    public class Account
    public string Name { get; set; }
    public double Value { get; set; }
    public override string ToString()
    return Name + " " + Value;
    #region IValueConverter Membersobject IValueConverter.Convert(object value, Type targetType, object parameter, CultureInfo culture)
    Account acct = value as Account;
    if (acct != null)
    return acct.Value;
    return null;
    object IValueConverter.ConvertBack(object value, Type targetType, object parameter, CultureInfo culture)
    return null;
    #endregion
