I have a xamDataGrid placed inside a user control. I do not set the width and height properties as I would like to conform to the width and height of the user control's container. I.e when the user resizes the window, the xamDataGrid should resize as well. If I do this, scrollbars do not appear and if set a width and height then I get a scrollbar but the xamDataGrid does not resize when the window is resized. Is there are workaround to this.
Ihsan
That is why I asked for your layout. The StackPanel measures its child controls with infinite height/width depending on its orientation. In your setup, you probably had a StackPanel with Vertical Orientation. Thus, the StackPanel measures its children with infinite height, so that is why the XamDataGrid does not have a scrollbar - it will be given as much space as it needs to display all of its content.
Hi Alex,
Thank you for your quick response. I have however solved this issue. Instead of using a stackpanel I use a grid. That seems to do the trick.. I don't know why though..
Hello Ihsan,
Can you please give us the markup for your window (where the user control is) and the markup of your usercontrol?
