We're using the xamchart in a UI where users are able to chose from a large set of data series to view on the chart, as well as pick the duration to be displayed. We're now seeing cases where if we hit some threshold number of data values (large number of series and/or a large number of data values per series), the background of the chart goes black. If we then eliminate any one series, or contract the duration, it immediately looks fine. (Note: it is not the case that the grid lines get closer and closer to evolve into a solid black background, which is what I first suspected when I took a look at this problem. It seems pretty well tied to the number of values).
Is there any limitation to the number of datapoints a chart can support? Is the expected behavior? a bug in the xamchart? Otherwise, any suggestions of what to look into on our part?
This issue still exists in 10.3.20103.2290. Any ideas?
To close the loop on this issue, we opened a case with Infragistics on this bug, and a fix became available in service releases for 9.1, 9.2, 10.1 and 10.2.
Thanks for looking into this, David. I tried your sample app and like you, I do not see the same issue we're running into. I'll need to dig further thru our xaml to see what other differences there may be to cause this. Unfortunately I'm out tomorrow, so I won't be able to jump back on this until Monday. Will catch up then...
i tried plotting 15 series of 100 and wasn't able to reproduce the issue of the background turning black. i have attached the sample project i used.
are you able to reproduce the problem using this sample? if so, what version of the chart dll are you using? if not, what steps am i missing to reproduce the problem?
Back on this thread here. We had opted not to implement this change back in February since it was too late in our release cycle. However, the issue has surfaced in the field, so we must now address it!!We did some further testing of your suggested workaround to disable fast rendering mode. With one graph with 1000 data points, the performance is reasonable after we take this approach. With more graphs, each with 1000 data points, performance degrades anywhere from 2x to 10x. Even with as few as four graphs - before the fix: 3.8s; after the fix: 39s!!It will not be unusual for our users to have graphs that are dense with data. And it appears the XamChart can otherwise handle large amounts of data well --- except for the caveat of the background turning black.We thus need another approach for this - whether a workaround that doesn't degrade as significantly, or a fix that corrects the background from being painted black when there are more than 999 data points in a graph.Suggestions?
