990
text wrapping field in grid
I'm stuck on something trivial! How do I set a field to wrap across several rows of the grid, ie a text field there there are 100's chars of text?
Setting Field.RowSpan seems to work if there are newlines, but not if I just want continous text to wrap.
  • 990
    Verified Answer
    For other's info, I found this explaination in the archive which works great:
    You need to set the TextWrapping of the XamTextEditor for that column.
    e.g.
       <igDP:XamDataGrid BindToSampleData="True">
        <igDP:XamDataGrid.FieldLayouts>
         <igDP:FieldLayout>
          <igDP:FieldLayout.Fields>
           <igDP:Field Name="name">
            <igDP:Field.Settings>
             <igDP:FieldSettings EditorType="{x:Type igEditors:XamTextEditor}">
              <igDP:FieldSettings.EditorStyle>
               <Style TargetType="{x:Type igEditors:XamTextEditor}">
                <Setter Property="TextWrapping" Value="Wrap"/>
               </Style>
              </igDP:FieldSettings.EditorStyle>
             </igDP:FieldSettings>
            </igDP:Field.Settings>
           </igDP:Field>
          </igDP:FieldLayout.Fields>
         </igDP:FieldLayout>
        </igDP:XamDataGrid.FieldLayouts>
       </igDP:XamDataGrid>
