335
Right align String column in code-behind...newbie question...
I have to right-align several columns thru code-behind in vb.  How can I specify which columns to align and how can I do this? I have been using the fieldlayout settings class, but I think I am missing something.
  • 395
    Suggested Answer
    I have similar code in C# but to center a column value (in code-behind). For a right-alignement I think I could just change the HorizonalAlignment to .Right instead of .Center. Here is a snippet of the code I'm using:
    In event for FieldLayoutInitialized -
    Style centerColumnStyle = new Style(typeof(CellValuePresenter));
    centerColumnStyle.Setters.Add(new Setter(CellValuePresenter.HorizontalAlignmentProperty, HorizontalAlignment.Center));
    Field
     someColumn = new Field();
    someColumn.Settings.CellValuePresenterStyle = centerColumnStyle;
    e.FieldLayout.Fields.Add(someColumn);
    Not sure on the VB equivalent but maybe you can convert this readily enough?
