On some machine installs, our new application making extensive us of Infragistic controls is giving the following fusion log error:
*** Assembly Binder Log Entry (12/17/2009 @ 5:05:48 PM) ***
The operation failed.Bind result: hr = 0x80070002. The system cannot find the file specified.
Assembly manager loaded from: c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorwks.dllRunning under executable C:\Documents and Settings\ripena\Local Settings\Apps\2.0\MMEZONOP.NYA\W52GTE69.81L\meas..tion_d3123b2d728a9cdf_0001.0000_402ddc1404a86ce4\Measurement.eFSR.exe--- A detailed error log follows.
=== Pre-bind state information ===LOG: User = JWOPERATING\ripenaLOG: DisplayName = Infragistics.License, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb (Partial)LOG: Appbase = file:///C:/Documents and Settings/ripena/Local Settings/Apps/2.0/MMEZONOP.NYA/W52GTE69.81L/meas..tion_d3123b2d728a9cdf_0001.0000_402ddc1404a86ce4/LOG: Initial PrivatePath = NULLLOG: Dynamic Base = NULLLOG: Cache Base = NULLLOG: AppName = Measurement.eFSR.exeCalling assembly : Infragistics3.Wpf.v9.1, Version=9.1.20091.2144, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb.===LOG: This bind starts in default load context.LOG: Using application configuration file: C:\Documents and Settings\ripena\Local Settings\Apps\2.0\MMEZONOP.NYA\W52GTE69.81L\meas..tion_d3123b2d728a9cdf_0001.0000_402ddc1404a86ce4\Measurement.eFSR.exe.configLOG: Using machine configuration file from c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\config\machine.config.LOG: Policy not being applied to reference at this time (private, custom, partial, or location-based assembly bind).LOG: Attempting download of new URL file:///C:/Documents and Settings/ripena/Local Settings/Apps/2.0/MMEZONOP.NYA/W52GTE69.81L/meas..tion_d3123b2d728a9cdf_0001.0000_402ddc1404a86ce4/Infragistics.License.DLL.LOG: Attempting download of new URL file:///C:/Documents and Settings/ripena/Local Settings/Apps/2.0/MMEZONOP.NYA/W52GTE69.81L/meas..tion_d3123b2d728a9cdf_0001.0000_402ddc1404a86ce4/Infragistics.License/Infragistics.License.DLL.LOG: Attempting download of new URL file:///C:/Documents and Settings/ripena/Local Settings/Apps/2.0/MMEZONOP.NYA/W52GTE69.81L/meas..tion_d3123b2d728a9cdf_0001.0000_402ddc1404a86ce4/Infragistics.License.EXE.LOG: Attempting download of new URL file:///C:/Documents and Settings/ripena/Local Settings/Apps/2.0/MMEZONOP.NYA/W52GTE69.81L/meas..tion_d3123b2d728a9cdf_0001.0000_402ddc1404a86ce4/Infragistics.License/Infragistics.License.EXE.LOG: All probing URLs attempted and failed.
Please help me to configure my application so that it will deploy with the correct liscense information.
Normal 0 false false false EN-IN X-NONE X-NONE
Hi Brian, Francis,
I am facing the similar issue. While opening the page designer, I am getting “The system cannot find the file specified. (0x80070002)” error. While opening WebDataGrid smart tag also getting the same error. I was able to open designer without any issue couple of days ago. However, now I am facing this issue.
I also tried to create new page from scratch with new WebDataGrid on it. However, faced the same issue.
Could you please let me know resolution for this issue?
Siddhanath
Brian,
Per our conversation today, I have opened support case CAS-37311-QE7W7Q for this issue. I will work with you through that case and I'll update the thread once we find the resolution.
Francis
