Alex,
Please see the attached solution.
The Records will disappear when the grid inside the dockable pane pinning.
Steps to reproduce:
1. Run the solution
2. Make dockable to right side (Welcome Screen pane).
3. Pin it.
result : The records will vanish
4. Unpin it.
Still the record wont appear.
5. If you do any grid operation like 'Sort' ..
The record will appear suddenly.
The same behaviour is in version 9.1.20091.2091 and 9.2.20092.2023.
(Only diffence is in 20091.2091 atleast Label header visible in pinning)
Any workaround for this?
Ramesh.P
This bug may be because of ReconCotainerGenerationMode = 'Recycle'.
If we change other then 'Recycle', the records are not vanish.
It may be infragistics issue.
Hi Alex,
Please find attached screenshot which i took at record vanish.
Hello Ramesh & Arthi,
I tested your sample on both Vista & XP using 9.2.20092.2023. I cannot reproduce this issue. Can you attach a screenshot of this behavior?
I am also facing same kind of issue. Is there any solution to solve this?
Thanks in advance,
Arthi
