400
How to Show MajorGridline for X axis at the start and end of Xamchart(Line).
   I am using the following XAML for XamChart
<igChart:XamChart x:Name="nodeChart"  Theme ="ThemePark" HorizontalAlignment ="Stretch"
MaxHeight="100" Background="{x:Null}" BorderBrush="{x:Null}" Margin ="0,3,0,6">
<igChart:XamChart.Scene>
<igChart:Scene MarginType="Percent">
<igChart:Scene.GridArea>
<igChart:GridArea Style="{StaticResource Gridarea}" MarginType="Percent" Margin="4,6,4,15"/>
</igChart:Scene.GridArea>
</igChart:Scene>
</igChart:XamChart.Scene>
<igChart:XamChart.Legend>
<igChart:Legend Visible="False"/>
</igChart:XamChart.Legend>
<igChart:XamChart.Series>
<igChart:Series ChartType="Area"
DataMapping="Value = ActiveNode; Label = TimeStamp"
DataSource="{Binding Path=ChartPointCollection, Mode=OneWay}"
Stroke="GreenYellow" Fill="GreenYellow" StrokeThickness ="4" Label ="Active Node"/>
<igChart:Series ChartType="Line" DataMapping="Value = AvailableNode; Label = TimeStamp; ToolTip=AvailableNode" DataSource="{Binding Path=ChartPointCollection, Mode=OneWay}"
StrokeThickness="2" Fill="DarkRed" Stroke=DarkRed" Label="Available Node"/>
</igChart:XamChart.Series>
<igChart:XamChart.Axes>
<igChart:Axis RangeFromZero="True" Stroke="#FFCCCCCC" StrokeThickness="1" Unit="8">
<igChart:Axis.MajorGridline>
<igChart:Mark Stroke="#4CFFFFFF"/>
</igChart:Axis.MajorGridline>
<igChart:Axis.MajorTickMark>
<igChart:Mark Stroke="#00808080"/>
</igChart:Axis.MajorTickMark>
<igChart:Axis.Label>
<igChart:Label Foreground="#FF787878" AutoResize="False" FontFamily="Tahoma" FontSize="9"/>
</igChart:Axis.>
</igChart:Axis>
<igChart:Axis AxisType="PrimaryY" Stroke="#FFCCCCCC" StrokeThickness="1" RangeFromZero
="True">
<igChart:Label Visible="False" Foreground="#FF787878" FontFamily="Tahoma" FontSize="9"/>
</igChart:Axis.Label>
</igChart:Axis>
</igChart:XamChart.Axes>
</igChart:XamChart>
Currently I am showing the MajorGridline after every 8 points added to chart (x axis represent time stamp).Now I am facing a problem to show MajorGridline when the first point is added.
 I tried to declear Unit = 0 in Xaml and change it to 8 from code after first point is added but it is removing the First MajorGridline as soon as Unit changes from 0 to 8.
Can u provide any solution to this problem?
Deep
  • 9836
    Hi Deep,
    I suppose that you need a major grid line on the first datapoint in the chart. One possible implementation is to add e.g. 8 (equals to the Unit) dummy points before your actual points. Here is one example:
    <igChart:Series.DataPoints>
              <igChart:DataPoint Value="0"/>
            <igChart:DataPoint Value="10"/>
            <igChart:DataPoint Value="20"/>
            <igChart:DataPoint Value="30"/>
            <igChart:DataPoint Value="40"/>
    </igChart:Series.DataPoints>
          <igChart:Mark Stroke="Red" Unit="2" />
    I hope this would work for your scenario.
    -Vlad
