746
Programatically Add Rows to Datasource problem
I have a xamdatagrid with an ado.net Dataset bound to it.  When I attempt to add new rows to the underlying dataset (e.g. table.newrow()   table.rows.Add(newrow))  I get a runtime exception stating that the row i am trying to add belongs to another table.  The status of the row is detached.  I made sure the table I created the new row from is the same table as the one i'm trying to add it to.  Is this expected behavior with the grid?  How can I programaticallly add a new row to the grid?  Thanks.
  • 440
    I couldn't reproduce your problem. The error you described is more likely to be related to misspelling in the names of the tables(e.g. table1.newrow()   table.rows.Add(newrow)).
    To test this - you can download xamFeatureBrowser (http://xamples.infragistics.com/) and in the samples under xamDataGrid->Layout and Behavior there is a sample Add Record. To test your case just add this code snippet in the end of the AddRecord_Samp_Loaded
    DataRow DR = ds.Tables[0].NewRow();
    DR[
    "Title"] = "NEW TITLE";
    ds.Tables[0].Rows.Add(DR);
