I have the following problem:
I specify the ItemsSource of a XamComboEditor as a list of instances of some generic class,
and bind the control to a property which type is the above-mentioned generic class type.
Now, I want to assign the ValueType property with that type. I do it this way:
ValueType = "{x:Type myNamespace:MyClass}".
The problem is the binding doesn't recognize MyClass as generic, and so there is an error in the binding.
My question is how can I assign the ValueType with a generic type?
Thanks.
Xaml currently doesn't support being able to specify a generic type using x:Type. You should either set the property in code or you could probably just set it to Object.
