I have build a number of pane header presenters to change the color of the content pane header. However, I could not find a property to attach the pane header presenter to a content pane. The only place I could find it was in the DockManger class.
Does this mean I can only change the background/foreground color of all the content panes? I would really like to change the backgroundforeground color of each content pane header individually based upon the content in the the pane.
Thanks, that did the trick. I was not aware of that function. It open up all kinds of styling options.
It is basically what I said - you would be manipulating the Resources of the ContentPane. So if you're changing the Style for the PaneHeaderPresenter it would be something like cp.Resources[typeof(PaneHeaderPresenter)] = myStyle;
Another way to approach this is to define you're own attached property, set the attached property on the contentpane to indicate its current state and then have 1 PaneHeaderPresenter style that has style/template trigger based on this property of the php's Pane and changes the background,etc.
I'm not clear how to do this. I am in C# code and I get an event from the ContentPane Control. I then get the ContentPane and I have the PaneHeaderPresenter I want to apply to the content pane. What I can't figure out is how to connect the two in c# code.
You could put your style or brush resources for the PaneHeaderPresenter in the Resources of the individual ContentPane instances.
