205
Fieldchooser horizontal instead of vertical
Not sure what has changed but the field chooser used to show the fields in a vertical format and now the fields are in a horizontal format.  What should I be looking for that might have changed?  Is the field chooser based on a listbox style?
Linda Rawson
  • 69686
    Suggested Answer
    Hello Linda,
    Actually the items control that the fields are held in is a ListBox. That is why if you have a style for the ListBox, this control will pick it up.
    However, I can see this behavior only if you define the style inside the XamDataGrid's resouces. One way to counter this effect is to move it somewhere else in the resources.
