905
How can I set customized resource strings to Reporting components ?
I want to localize to Reporting components' dialogs and screens to Turkish.
I can set the customized string to Ribbon with the following statement.
Infragistics.Windows.Ribbon.Resources.Customizer.SetCustomizedString("ToolContextMenu_ShowQatBelowRibbon", "Hzl Eriim Ara ubuunu Ribonun Altnda Gster");
So , How can I set Reporting customized resource strings ?
but I can not set the customized string to Reporting resources with following statement;
Infragistics.Windows.Reporting.
Becouse Infragistics.Windows.Reporting can not include Resources class.
  • 12773
    Suggested Answer
    Here you can find the reporting resource string that can be customized:
    http://help.infragistics.com/Help/NetAdvantage/WPF/2009.2/CLR3.5/html/WPF_Reporting_Resource_Strings.html
    And here are all available customizable strings:
    http://help.infragistics.com/Help/NetAdvantage/WPF/2009.2/CLR3.5/html/WPF_Assembly_Resource_Strings.html
    You can use the same method of Resource Customizer -SetCustomizedString in order to set Reporting text to be customize.
    I hope this helps.
    Sincerely,
    Dimi
    Developer Support Engineer
    Infragistics, Inc.
