I have a xamDatagrid. The Data comes with a Binding to a DataTable. In this DataTable I have set the DefaultValue Property for each Column.
Now when I Click into the AddNew-Row the DefaultValue is shown as soon as I typ in a Value. But I would like to show the DefaultValues as soon as I click into the AddNew-Row.
Is there any solution for this?
Thank you for the solution. But it doesn't work for me.
I have a DataTable as DataSource of the Grid. And in this DataTable i've set the DefaultValue for each Column.
When I Add the Code for EditModeStarted nothing happens. (The code executes but the DefaultValue is not shown).
So there is a Difference for the Grid between the DefaultValue set in a bindet DataTable and the Value you set in the constructor of your Class for the BindingList.
Is there a posibility to achiev that behavior with a bound DataTable?
I am attaching a small sample with this functionality. What you need to do is switch the value of the underlying editor so that the new object can be created right away.
