Hi
The XamRibbon automatically shows KeyTips when the Alt-Key is pressed. Is it possible to prevent this behavior?
What's more, the Ribbon behaves really strange if it is collapsed. See the attached Screenshots:
Ribbon visible, Alt key pressed:
Ribbon collapsed, Alt key pressed:
We need to make sure, that at least no KeyTips show up if the Ribbon is collapsed. Even better if we could get rid of them altogether.
Thanks,Patrick
<Window x:Class="WpfApplication2.Window1" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:r="http://infragistics.com/Ribbon" Title="Window1" Height="300" Width="300"> <Window.Resources> <BooleanToVisibilityConverter x:Key="boolToVisibility" /> </Window.Resources> <DockPanel> <r:XamRibbon DockPanel.Dock="Top" Visibility="{Binding ElementName=visible, Path=IsChecked, Converter={StaticResource boolToVisibility}}"> <r:XamRibbon.Tabs> <r:RibbonTabItem Header="Tab 1"> <r:RibbonGroup Caption="Group 1"> <r:ButtonTool Caption="Tool 1"/> <r:ButtonTool Caption="Tool 2"/> </r:RibbonGroup> </r:RibbonTabItem> <r:RibbonTabItem Header="Tab 2"> <r:RibbonGroup Caption="Group 2"> <r:ButtonTool Caption="Tool 3"/> <r:ButtonTool Caption="Tool 4"/> </r:RibbonGroup> </r:RibbonTabItem> </r:XamRibbon.Tabs> </r:XamRibbon> <Grid Background="Red"> <ToggleButton Margin="20" Content="Visible" Name="visible" /> </Grid> </DockPanel></Window>
Any news on the second part (Bug)?
patrickmaurer said: The XamRibbon automatically shows KeyTips when the Alt-Key is pressed. Is it possible to prevent this behavior?
patrickmaurer said:We need to make sure, that at least no KeyTips show up if the Ribbon is collapsed
