I have a number of columns that are type checkbox. I wish to allow the user to multi select cells by left clicking as shown in the my projects xamDataGrid image below.
I have my CellClickAction set as follows:
<igDP:FieldSettings CellClickAction="SelectCell" LabelTextWrapping="Wrap">
</igDP:FieldSettings>
The problem I am having is that the user must now double-click a checkbox in order to toggle the value. I would like it so they could single click an individual checkbox to toggle it. But if they want to select a range they could left-click within the cell but outside of the checkbox and then drag to select a range because I am going to be displaying a context menu that allows them to check/uncheck the selected range. It is not a requirement that they click outside of the checkbox, I am just looking for a way for the user to accomplish the behavior, so if you have another suggestion that is ok.
So I think the only question at this point is: The grid is functioning fine, but how can I make it so the user can single click a checkbox and have it toggle.
This behavior is because you have set the CellClickAction to Select Cell. As its name implies, when you click on a cell, it will select it. You would have to perform another click in order to enter edit mode. This is the expected behavior of the XamDataGrid.
