195
Ribbon Recently Used Items
How do you open/navigate a page or window when clicking on a recently used item in the application menu?  I have seen the help file on how to add the item to menu, but not sure how to set it to know where to navigate.  I have a main navigation hub that contains carousel images to open sub-applications (Mainly pages viewed in a Frame ).  Once the sub-app is opened, it would be nice to add the sub-app name to the recently used list to allow quick navigation back to that page/window.  Thanks in advance.
  • 8576
    Hi -
    Since the XamRibbon has no intrinsic understanding of the items you place in the ApplicationMenu.RecentItems collection, you need to provide enough information (context) on the individual items to allow your code to 'know what to do' when the item is clicked.  For example, if you are adding items that are derived from FrameworkElement you can store some information (e.g., a filename) in the Tag property of the element that you can reference when the item is clicked on.
    JoeM
  • 4850
    There is a RecentItems collection property off the ApplicationMenu object. You can pre-populate this from xaml or thru procedural code. You can add any element to this collection, either tools or even Button controls. The following xaml shows the adding of a ButtonTool to the RecentItems collection and wiring up its click event, in code you could add to the collection via the this.XamRibbon1.ApplicationMenu.RecentItems.Add() method:
    <igRibbon:XamRibbon.ApplicationMenu>
    <igRibbon:ApplicationMenu>
    <igRibbon:ApplicationMenu.RecentItems>
    <igRibbon:ButtonTool Caption="Some stuff" Click="OnToolClick" SmallImage="\Images\16x16.png"/>
    </igRibbon:ApplicationMenu.RecentItems>
    </igRibbon:ApplicationMenu>
    </igRibbon:XamRibbon.ApplicationMenu>
