We're trying to deselect all selected records when the user clicks anything but a record.
For example, in the attached image, if the user clicks the circled area, the parent record ("Biography") is selected. We would like to deselect all records when this happens.
Any ideas?
Matt
Matt,
For the Microsoft.Windows.Themes.ScrollChrome element you need explicitly to add a reference to the PresentationFramework.Luna.dll. The Visual Studio will not do that for you, as it does for in other cases.
To make it scroll, you just have to remove e.Handled=true as this is preventing it.
Shoot,
I just noticed, that if you click a scroll bar.. the bar will not scroll.
I tryed:
Microsoft.Windows.Themes.ScrollChrome sc = Infragistics.Windows.Utilities.GetAncestorFromType( e.OriginalSource as DependencyObject, typeof(Microsoft.Windows.Themes.ScrollChrome), true) as Microsoft.Windows.Themes.ScrollChrome; // If clicking on the Scroll bar - do nothing if (sc != null) return;
but there is no such "Microsoft.Windows.Themes.ScrollChrome"
which if u put your mouse over the scroll bar and use a breakpoint.. you can see that is what the system recognises it as.
Thanks, Matt.
Thanks much, works great!
-Matt.
I now realized from your first screenshot that you are using 9.1 version - in 9.2 we have bubbles :) . So here it is why it's working with me and not with you:
In 9.2, we are not using nested panels for the nested records. So, when I am clicking beside the record, it returns null. In 9.1, this returns the presenter of the parent record, because it surrounds the nested records. That is why the parent record is selected. This however would require some more if-s, because you need to be sure when to deselect the record - basically in all the cases that you would not select it.
Here is a sample code snippet. Please test/run it and let me know of the result:
void xamDataGrid1_PreviewMouseLeftButtonDown(object sender, MouseButtonEventArgs e)
RecordSelector rs = Infragistics.Windows.Utilities.GetAncestorFromType(
typeof(RecordSelector), true) as RecordSelector;
// If clicking on the record selector - do nothing
if (rs != null)
return;
ExpansionIndicator expInd = Infragistics.Windows.Utilities.GetAncestorFromType(
typeof(ExpansionIndicator), true) as ExpansionIndicator;
// If clicking on the expansion indicator - do nothing
if (expInd != null)
CellValuePresenter cvp = Infragistics.Windows.Utilities.GetAncestorFromType(
typeof(CellValuePresenter), true) as CellValuePresenter;
// If clicking in the cells - do nothing
if (cvp != null)
// Finally check for the area and deselect the record
DataRecordCellArea area = Infragistics.Windows.Utilities.GetAncestorFromType(
typeof(DataRecordCellArea), true) as DataRecordCellArea;
if (area == null)
xamDataGrid1.ExecuteCommand(DataPresenterCommands.ClearAllSelected);
xamDataGrid1.ActiveRecord = null;
e.Handled = true;
I noticed that as well. I am going to look into this and update this thread when I have more information on it.
