360
Scroll Behaviour
I finally got the records to scroll in my xamDataGrid by removing a style, i am not sure why the style affects the scroll behavior though.  I have included it below in case anyone can see a problem with it.
My next question is how to get the scrolling smooth.  It takes several seconds from the time i click the scroll until the records change.  I have all virtualization turned off hoping that would help, but it didn't make a difference.  My xaml for the grid is also below:
<!-- GRID -->
<igDP:XamDataGrid Name="grid" Theme="ForestGreen" AutoFit="True" SelectedItemsChanged="grid_SelectedItemsChanged" >
            <igDP:XamDataGrid.FieldSettings >
                <igDP:FieldSettings  CellClickAction="SelectRecord" AllowEdit="False" AllowSummaries="True" AllowGroupBy="True" AllowCellVirtualization="False" LabelTextWrapping="WrapWithOverflow" SummaryDisplayArea="BottomFixed" />
            </igDP:XamDataGrid.FieldSettings>
             <igDP:XamDataGrid.Resources>
                <Style TargetType="{x:Type igDP:CellValuePresenter}" x:Key="ScheduleImageCellStyle">
                    <Setter Property="Template">
                        <Setter.Value>
                            <ControlTemplate TargetType="{x:Type igDP:CellValuePresenter}">
                                <Grid Width="70" Height="70" Margin="2">
                                    <Border BorderBrush="#DDDDDD" BorderThickness="1" HorizontalAlignment="Center" VerticalAlignment="Center">
                                        <Image Width="32" MaxHeight="64" MaxWidth="64" Source="{Binding RelativeSource={RelativeSource TemplatedParent}, Path=Content}" />
                                    </Border>
                                </Grid>
                            </ControlTemplate>
                        </Setter.Value>
                    </Setter>
                </Style>
            </igDP:XamDataGrid.Resources>
            <igDP:XamDataGrid.FieldLayoutSettings>
                <igDP:FieldLayoutSettings AutoGenerateFields="False" />
            </igDP:XamDataGrid.FieldLayoutSettings>
            <igDP:XamDataGrid.FieldLayouts>
                <igDP:FieldLayout>
                    <igDP:FieldLayout.FieldSettings>
                        <igDP:FieldSettings AllowEdit="False" CellClickAction="SelectRecord" />
                    </igDP:FieldLayout.FieldSettings>
                    <igDP:FieldLayout.Fields>
                        <igDP:Field Name="ImageFile"  Label="Budget Status">
                            <igDP:Field.Settings>
                                <igDP:FieldSettings CellHeight="64" CellWidth="64"
                                            CellValuePresenterStyle="{StaticResource ScheduleImageCellStyle}"
                                            CellMaxWidth="100" LabelMaxWidth="100"/>
                            </igDP:Field.Settings>
                        </igDP:Field>
                        <igDP:Field Name="WorkOrder" Label="Work Order">
                                <igDP:FieldSettings CellHeight="25"   AllowGroupBy="True"/>
                        </igDP:Field>
                        <igDP:Field Name="WOOperation" Label="Operation">
                                <igDP:FieldSettings CellHeight="25" AllowGroupBy="True" >
                                </igDP:FieldSettings>
                        </igDP:Field>
                        <igDP:Field Name="WOSubOperation" Label="Sub-Operation">
                        </igDP:Field>
                        <igDP:Field Name="Location" Label="Location" >
                        </igDP:Field>
                        <igDP:Field Name="Description" Label="Description">
                                <igDP:FieldSettings CellHeight="200" AllowGroupBy="True" >
                                    <igDP:FieldSettings.EditorStyle>
                                        <Style TargetType="{x:Type igEditors:XamTextEditor}">
                                            <Setter Property="TextWrapping" Value="Wrap" />
                                        </Style>
                                    </igDP:FieldSettings.EditorStyle>
                        </igDP:Field>
                        <igDP:Field Name="ProjectedCost" Label="Projected Cost">
                                <igDP:FieldSettings CellHeight="25" AllowGroupBy="True" AllowSummaries="True" >
                                        <Style TargetType="{x:Type igEditors:XamCurrencyEditor}"/>
                        </igDP:Field>
                        <igDP:Field Name="ProjectedHours" Label="Projected Hours">
                                <igDP:FieldSettings CellHeight="25" AllowGroupBy="True" AllowSummaries="True">
                                        <Style TargetType="{x:Type igEditors:XamTextEditor}"/>
                        </igDP:Field>
                        <igDP:Field Name="ProjectedBilling" Label="Projected Billing">
                        </igDP:Field>
                        <igDP:Field Name="ActualCost" Label="Actual Cost">
                        </igDP:Field>
                        <igDP:Field Name="ActualHours" Label="Actual Hours">
                                <igDP:FieldSettings CellHeight="25" AllowGroupBy="True">
                        </igDP:Field>
                        <igDP:Field Name="ActualBilling" Label="Actual Billing">
                        </igDP:Field>
                    </igDP:FieldLayout.Fields>
                </igDP:FieldLayout>
            </igDP:XamDataGrid.FieldLayouts>
        </igDP:XamDataGrid>
<!--- ScrollViewer Style that messes up scroll behaviour -->
<Style  TargetType="ScrollViewer">
        <Setter Property="HorizontalContentAlignment"
            Value="Left" />
        <Setter Property="VerticalContentAlignment"
            Value="Top" />
        <Setter Property="Padding"
            Value="4" />
        <Setter Property="BorderThickness"
            Value="1" />
        <Setter Property="BorderBrush"
            Value="{StaticResource NormalBorderBrush}" />
            <Setter.Value>
                <ControlTemplate TargetType="ScrollViewer">
                    <Border BorderBrush="{TemplateBinding BorderBrush}"
                  BorderThickness="{TemplateBinding BorderThickness}"
                  CornerRadius="2">
                        <Grid Background="{TemplateBinding Background}">
                            <Grid.ColumnDefinitions>
                                <ColumnDefinition Width="*" />
                                <ColumnDefinition Width="Auto" />
                            </Grid.ColumnDefinitions>
                            <Grid.RowDefinitions>
                                <RowDefinition Height="*" />
                                <RowDefinition Height="Auto" />
                            </Grid.RowDefinitions>
                            <ScrollContentPresenter Cursor="{TemplateBinding Cursor}"
                                      Margin="{TemplateBinding Padding}"
                                      x:Name="ScrollContentPresenter"
                                      ContentTemplate="{TemplateBinding ContentTemplate}" />
                            <Rectangle Grid.Column="1"
                         Grid.Row="1"
                         Fill="#FFE9EEF4" />
                            <ScrollBar IsTabStop="False"
                         x:Name="PART_VerticalScrollBar"
                         Width="18"
                         Visibility="{TemplateBinding ComputedVerticalScrollBarVisibility}"
                         Grid.Column="1"
                         Grid.Row="0"
                         Orientation="Vertical"
                         ViewportSize="{TemplateBinding ViewportHeight}"
                         Maximum="{TemplateBinding ScrollableHeight}"
                         Minimum="0"
                         Value="{TemplateBinding VerticalOffset}"/>
                         Height="18"
                         x:Name="PART_HorizontalScrollBar"
                         Visibility="{TemplateBinding ComputedHorizontalScrollBarVisibility}"
                         Grid.Column="0"
                         Grid.Row="1"
                         Orientation="Horizontal"
                         ViewportSize="{TemplateBinding ViewportWidth}"
                         Maximum="{TemplateBinding ScrollableWidth}"
                         Minimum="0"
                         Value="{TemplateBinding HorizontalOffset}"/>
                        </Grid>
                    </Border>
                </ControlTemplate>
            </Setter.Value>
        </Setter>
    </Style>
