195
Date Validation using XamDateTimeEditor
    I need to basically ensure that the user does not select a date less than todays date. I tried to use the value constraint as below. I did not get this working since I try to attach a custom object as a value for the "MinInclusive" field.
   If I give a hard coded date it validates correctly. Can anyone suggest how to bind my custom object to the MinInclusive field? Im using MVVM pattern
<igDP:Field Name="AuditScheduledDate">
                                <igDP:Field.Settings>
                                    <igDP:FieldSettings EditorType="{x:Type igEdit:XamDateTimeEditor}" EditAsType="{x:Type Sys:DateTime}">
                                        <igDP:FieldSettings.EditorStyle>
                                            <Style TargetType="{x:Type igEdit:ValueEditor}">
                                                <Style.Setters>
                                                    <Setter Property="ValueConstraint">
                                                        <Setter.Value>
                                                            <igEdit:ValueConstraint MinInclusive="{Binding Path=MinDate, Mode=TwoWay}" MaxInclusive="01/01/2050" />
                                                        </Setter.Value>
                                                    </Setter>
                                                    <Setter Property="InvalidValueBehavior" Value="RetainValue" />
                                                </Style.Setters>
                                                <Style.Triggers>
                                                    <Trigger Property="IsValueValid" Value="false">
                                                        <Trigger.Setters>
                                                            <Setter Property="BorderBrush" Value="Red" />
                                                        </Trigger.Setters>
                                                    </Trigger>
                                                </Style.Triggers>
                                            </Style>
                                        </igDP:FieldSettings.EditorStyle>
                                    </igDP:FieldSettings>
                                </igDP:Field.Settings>
                            </igDP:Field>
Ranjith
