Hi
I have the following problem:
I initialize XamDataGrid layout in code-behind in FieldLayoutInitializing event handler. Some of the fields are defined as Hidden right from the start, but can be Unhidden by the user in run-time. The problem is when I make those field visible again, by setting:
field.Visibility =
Visibility.Visible
they don't appear in the group-by area.
How can I fix it, so the previously hidden fields, when become visible will also appear in the group-by area?
As I am not able to reproduce this with the service release, please make sure that you download and test this with it. If the problem still exists, please provide us with a small sample with this behavior.
Thanks.
Version - 9.1.20091.1006
Runtime Version - v2.0.50727
Thank you
Could you give us the exact dll build number of the dlls?
Hi Alex,
I'm using the v9.1 version
I was not able to reproduce this issue following your steps to reproduce. Which version of our dlls are you using?
