225
How to display Int data in Dataset as String in grid
I have a column in a datacontext which is an integer( 0,1)
While displaying these in the Xamdatagrid, i want to display: 0 as "NO" & 1 as "Yes".
Could somebody please guide me thru this?? Thanks!!
  • 69686
    Suggested Answer
    For this, you can use IValueConverter class and apply it to the Field's Converter property. the converter would look something like this:
    class ValueToEnumConverter :IValueConverter
            public object Convert(object value, Type targetType, object parameter, System.Globalization.CultureInfo culture)
                if (value == null)
                    return Binding.DoNothing;
                if (value.ToString() == "1")
                    return "Yes";
                else
                    return value;
    Hope this helps.
