1886
XamComboEditor (IsEditable) and Custom ContextMenu Problems
Hello,  I have a XamComboEditor that I want to have display a custom Context menu when it is right clicked.  Create ContextMenu resource, set contextMenu Property - everything is fine...
UNTIL you set the XamComboEditor IsEditable property = true!!!!
with IsEditable = true, the custom menu only appears when the Drop Down arrow or the dropdown items are right clicked.  If you right click in the text area - it displays the basic editing context menu (Cut, Copy, Paste)
How do i get the custom menu to appear all the time on a right click when iseditable = true!!!!!
thanks
Rod
<ContextMenu x:Key="PrmXContextMenu" >
   <MenuItem Header="Cut"  />
   <MenuItem Header="Copy"  />
   <MenuItem Header="Paste" />
   <Separator/>
   <MenuItem Header="Add Record"  />
   <MenuItem Header="Insert Record"  />
   <MenuItem Header="Delete Record"  />
   <MenuItem Header="Move Record"  >
      <MenuItem Header="Move Record Up" />
      <MenuItem Header="Move Record Down"  />
   </MenuItem >
</ContextMenu>
 <igEditors:XamComboEditor x:Name="ddDoWhat" Margin="5,0,3,3" ContextMenu="{StaticResource PrmXContextMenu}" IsEditable="True" >
   <igEditors:XamComboEditor.ItemsProvider>
      <igEditors:ComboBoxItemsProvider >
         <igEditors:ComboBoxItemsProvider.Items>
            <igEditors:ComboBoxDataItem DisplayText="Replace (1)" Value="1"/>
            <igEditors:ComboBoxDataItem DisplayText="Add (0)" Value="0"/>
         </igEditors:ComboBoxItemsProvider.Items>
      </igEditors:ComboBoxItemsProvider>
   </igEditors:XamComboEditor.ItemsProvider>
</igEditors:XamComboEditor>
