I can't seem to find the property or method to change what value is shown as you drag scrollbar up and down. Currently it seems to set to the first property of an item in the collection. Any way to set this to another column?
Rick
Thank you, I did not look in the field class.
Hello Rick,
Each field exposes a IsScrollTipField property which you can use to change this. The default value is the first column. Moreover, if you like to go one step further, you can retemplate this scrolltip using the default style (which we ship in the DefaultStyles directory) and create a custom one.
Hope this helps.
Hi Rick,
You are probably looking for the IsScrollTipField property which by default is set to true for the first field. For more details you can refer to the online documentation :
(http://help.infragistics.com/Help/NetAdvantage/WPF/2009.1/CLR3.X/html/xamData_Displaying_ToolTips_While_Scrolling_the_Grid.html)
Regards
Vlad
