20
Jagged array and Hierarchical data binding
I have some problems with a jagged array.
If I leave the default behaviour when I set a jagged array as datasource of a datagrid I see it as an  hierarchical data binding.
I don't want this behaviour because I want to see it as a bidimensional array, but if a try to set the fields manually I can't see nothing.
Can you tell me what I'm doing wrong? What's the easiest way to display a jagged array as a normal bidimensional array?
Thank you
Simone
  • 8576
    Hi -
    Can you provide a sample that shows how you are 'setting the fields manually'?
    Joe Modica
