I have created an UI using DockManager.It has a SplitPane to divide the UI into left and right panes. On the right pane, I have a TabGroupPane on which I have two ContentPanes. Each ContentPane has a XAML UserControl embedded. Everything looks ok. But if the user close a ContentPane, how can we bring it back to view?
<igDock:TabGroupPane> <!-- Use the Image property to add Icons to each Content Pane --> <igDock:ContentPane x:Name="rightEdgeDock" Header="pane1"> <local:StoryLibraryContent x:Name="m_p1" /> </igDock:ContentPane> <igDock:ContentPane x:Name="rightEdgeTeamDock" Header="pane2"
> <local:WireLibraryContent x:Name="m_p2" /> </igDock:ContentPane> </igDock:TabGroupPane>
I noticed that if the ContentPane get closed, the m_p1.IsVisible will be set to false. I think by setting this to true will bring the content back. Problem is we cannot do this directly, it's a read only property. We also have a m_p1.Visibility property, but when pane get closed, this property remains value "visible".
My question is how can we set the m_p1.IsVisible to true? or is there another way to do this? Thanks.
ah...... thanks for the tips. You are right I was checking the visibility of the UserControl. The visibility of the ContentPane should be checked.
youkebb said: this is not true for me, the Visibility remained "Visible" all the time... Don't know what's wrong
http://news.infragistics.com/forums/p/17580/63772.aspx#63772
i was reading this post, in one of the replies there's the following statement:
If the CloseAction is left to the default - HidePane - then when the pane is closed (e.g. clicking the X in the pane header) its Visibility is set to Collapsed. To reshow the pane you would just set its Visibility back to Visible.
