I kept a style for context menu in xam grid in grid resources..How can i set a the other style for
alternative row record For the same datarecordCellArea as target type..
error is coming tat 2 styles cannot be setted for grid styles..
any other way to set the alternative row color..i want to set blue or brown color for alternative rows...
<Style TargetType="{x:Type igDP:DataRecordCellArea}" > <Setter Property="ContextMenu" Value="{StaticResource imageMenu}" /> </Style>
You can try with the following style for the DataRecordCellArea:
<Style TargetType="{x:Type igDP:DataRecordCellArea}"> <Style.Triggers> <DataTrigger Binding="{Binding Path=IsAlternate, RelativeSource={RelativeSource Self}}" Value="True"> <Setter Property="ContextMenu" Value="{StaticResource menu1}"/> </DataTrigger> <DataTrigger Binding="{Binding Path=IsAlternate, RelativeSource={RelativeSource Self}}" Value="False"> <Setter Property="ContextMenu" Value="{StaticResource menu2}"/> </DataTrigger> </Style.Triggers> </Style>
Hope this helps
Vlad
