I have a problem using Carousel List Box, The Problem is I have a User Control having an Outline as below
Border-->Stack Panel-->Grid having 2 columns
I have set all the width and height properties to Auto.
My Problem is when i am using this User Control in a Carousel ListBox, normally the Items in the Carousel looks pretty much fine but when i try to select an Item, i get a Grey Background of the usercontrol which i looking awkward...how can i solve this problem...Please help me out
Thanks in Advance
Ram
Hi Alex,Thanks for the reply, i have tried the style it is working fine...Thanks a Ton !!!
Hello Ram,
This is be default - the selected item gets highlighted for visual appearance. You can do that by retemplating the CarouselListBoxItem. You can find the generic xaml files in the DefaultStyles for this. I am attaching the one I took from that directory modified - the selected item will have transparent background.
Let me know if you have further questions on this.
