1255
How to prevent the expander from expanding
For some data records, I have used the xamdatagrid recordexpanding event to launch a new new window to edit the remaining part of the data structure in a second xamdatagrid.  I do this to reduced the complexity presented to the end user.  On those few records where I launch a new window I want to prevent the grid expander from expanding the rest of the data structure.
I don't know if this is an bug but I tried setting the e.Handled to true in the recordexpanding event.  However, it doesn't stop the rest of the grid from expanding.
Any thoughts on how to do this?
  • 69686
    Suggested Answer
    This is not an issue. The RecordExpanding is a cancelable event. Instead of handling it, you should cancel it instead like this:
    e.Cancel = true;
    This will do the trick.
    Hope this helps.
