I created a control template as I have with the standard controls, but when creating a control template for the xamNumericEditor, it is not applying. See below:
<ResourceDictionary xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:igEditors="http://infragistics.com/Editors" >
<!-- SimpleStyles: TextBox --> <Style TargetType="{x:Type igEditors:XamNumericEditor}"> <Setter Property="Template"> <Setter.Value> <ControlTemplate TargetType="{x:Type igEditors:XamNumericEditor}"> <ControlTemplate.Triggers> <Trigger Property="IsEnabled" Value="False"> <Setter Property="Background" Value="White"/> <Setter Property="BorderBrush" Value="White"/> <Setter Property="Foreground" Value="Black"/> </Trigger> </ControlTemplate.Triggers> </ControlTemplate> </Setter.Value> </Setter> </Style></ResourceDictionary>
I am just trying to create a label effect when the IsEnabled property equals false. Please advise
Actually, you do not need to create control template triggers. You can use the Style Triggers and not have to retemplate the Template:<Style TargetType="{x:Type igEditors:XamNumericEditor}">
<Style.Triggers>
</Trigger>
</Style.Triggers>
</Style>
However, you can see the default styles for the ValueEditors in the DefaultStyles directory in the Infragistis folder.
Hope this helps
