Can you provide some sample code of paging in xamDataGrid. Also for searching in populated grid.
Shantanu.
It’s Infragistics policy to not pre-announce features until they have gone through QA cycle and are marked for release so we can't give you specifics on dates. However, this is a feature that has been requested before and is in our list of features to consider for feature releases. The implementation of the feature in upcoming releases depends on the number of customer requests logged at http://devcenter.infragistics.com/Protected/RequestFeature.aspx so one more customer vote will move it up in the priority list.
Best Regards,Yanko
I already have a request opento include native paging feature in XamDataGrid. We have a use case of displaying a lot of data on the page in a hierarchical fashion with paging enabled at all the levels.. i.e. lets say you have customers and then it has child records from Order tables then one should be able to page through both customer and order. Do you have any updates on this, like when this feature could be delivered?
Maulik.
I tried to use UltraDataSource to xamDataGrid howerver I got exception that UltraDataSource is not IEnumerable type.
UltraDataSource sr = new UltraDataSource();
XamDataGrid grid1 = new XamDataGrid()
grid1.DataSource =sr;
Can you help on this.
I would like to try to perform paging by my self. Is there an event exposed that would enable me to trap the moment the user reachs the first or last item of the list when scrolling in the list? Is there an event exposed that trap the header click event?
Tanks
Karine
