144
Programmatically setting SplitPane's InitialLocation when using NCAL
I'm using DockManager in a Composite WPF application via the NCAL. When one of my my modules loads, I want it to add itself to the DockManager on the right-hand side. I cannot figure out how to do this programmatically.
Using the example code works fine:
   Style content_style = new Style(typeof(ContentPaneProxy));
   content_style.Setters.Add(new Setter(ContentPane.HeaderProperty, "Pane Header"));
   XamDockManagerSettings.SetContentPaneProxyStyle((DependencyObject)view_object, content_style);
   XamDockManagerSettings.SetIsContentPaneInTabGroup((DependencyObject)view_object, true);
   XamDockManagerSettings.SetSplitPaneName((DependencyObject)view_object, "SplitPaneName");
   this.mRegionManager.Regions["MainRegion"].Add(view_object, "ViewName");
But this causes the new view to be added as a split pane on the left. I want the InitialLocation to be DockedRight.
I tried setting the SplitPaneProxy style, but that didn't work (got an exception, "The 'InitialLocation' property is only intended for SplitPane instances in the Panes collection of the XamDockManager"):
   Style split_pane_style = new Style(typeof(SplitPaneProxy));
   split_pane_style.Setters.Add(new Setter(XamDockManager.InitialLocationProperty, Infragistics.Windows.DockManager.InitialPaneLocation.DockedRight));
   XamDockManagerSettings.SetSplitPaneProxyStyle((DependencyObject)view_object, split_pane_style);
I also tried calling the SetInitialLocation, which also triggered the same exception:
   XamDockManager.SetInitialLocation((DependencyObject)view_object, Infragistics.Windows.DockManager.InitialPaneLocation.DockedRight);
