445
XamNumericEditor binding problem inside control template
We have binding problem with our user control that uses XamNumericEditor. The problem occurs when we try simple binding with XamNumericEditor that is inside a usercontrol and which is styled through a control template.
The problem does not occur when we use editors which do not use storyboards (which we assume) such as XamTextEditor. However, the problem occurs with controls such as XamMaskedEditor, XamNumericEditor.
As you can see with the attached sample Project, we can not bind our usercontrol  that uses XamNumericEditor, to our Amount property.
You can open the attached project and run the sample. Notice, that the NumericEditor which contains XamNumericEditor has a binding problem in control template. The one outside the control template works fine.
InfraNumericEditorControlTemplateBindingProblem.zip
  • 69686
    Suggested Answer
    You can try binding the Value property to the root's Text property rather than the Text like this:
            <igEditors:XamNumericEditor Grid.Row="0" Grid.Column="1" x:Name="ControlEditor" Value="{Binding ElementName = root, Path = Text}" Width="100" ></igEditors:XamNumericEditor>
    A Developer Support Engineer is also handling your support case on this issue.
