695
Drag and Drop functionality
Does this control support drag and drop functionality and if so could you povide me with some sample code?
  • 600
    This is what I did:
    Item Templete:
    <igWindows:XamCarouselListBox.ItemTemplate>
     <DataTemplate DataType="Imagen">
      <Grid Width="150" Height="150" Margin="0,0,0,0" >
       <Grid.RowDefinitions>
        <RowDefinition Height="Auto"/>
       </Grid.RowDefinitions>
       <Image Source="{Binding RutaCompleta, Converter={StaticResource imageUriConverter}}"
                       Tag="{Binding IdImagen, Mode=OneWay}"
                       HorizontalAlignment="Left" Width="150" Height="150" VerticalAlignment="Top"
                       MouseLeftButtonDown="DragImage" />
      </Grid>
     </DataTemplate>
    </igWindows:XamCarouselListBox.ItemTemplate>
    Code:
            private void DragImage(object sender, MouseButtonEventArgs e)
                try
                    Image image = e.Source as Image;
                    if (e.ClickCount == 2)
                        this.SelectedImage.Source = image.Source;
                        ActualizarTexto();
                    else
                        imagen = GetDataFromListBox(e.GetPosition(ImagenesListBox)) as Imagen;
                        if (imagen != null)
                            this.ImagenesListBox.SelectedItem = imagen;
                        DataObject data = new DataObject(typeof(ImageSource), image.Source);
                        DragDrop.DoDragDrop(image, data, DragDropEffects.Copy);
                catch (Exception ex)
                    MessageBox.Show(ex.ToString());
            private void DropImage(object sender, DragEventArgs e)
                try
                    ImageSource image = e.Data.GetData(typeof(ImageSource)) as ImageSource;
                    if (image != null)
                        this.SelectedImage.Source = image;
                        ActualizarTexto();
            private object GetDataFromListBox(Point point)
                UIElement element = ImagenesListBox.InputHitTest(point) as UIElement;
                object data = DependencyProperty.UnsetValue;
                while (data == DependencyProperty.UnsetValue && element != null)
                    data = ImagenesListBox.ItemContainerGenerator.ItemFromContainer(element);
                    if (data == DependencyProperty.UnsetValue)
                        element = VisualTreeHelper.GetParent(element) as UIElement;
                    ContentPresenter content = element as ContentPresenter;
                    if (content != null)
                        data = content.Content;
                        break;
                if (data != DependencyProperty.UnsetValue)
                    return data;
                return null;
    I hope this example will help you.
    Jaimir G. [MVP]
