Not sure why I can't find an example of how to make a column in the xamDataGrid a column of dropdown values that are bound. I've found examples of UnBoundField, but not bound. Does anyone have an example of this?
That's perfect -- thank you!
You can find an example for that in the XamFeatureBrowser, which is installed with our suite. The example is under XamDataGrid - Control Composition - XamComboEditor in DataRecord Cells
Hope this helps.
