The Pinning option that is provided in the 9.1 version is very cool. Thanks for this option.
But i have a problem here,
When i unpin the column, it goes to the first or last place. I want the place to be intact, for example, if i pin the 4th column, it goes to the left most edge and pins, this is fine. When i unpin that column, i expect it at the 4th place itself, not at the 1st column.
Is it possible to retain the column position??
Thanks in advance.
Sreeram.
I am also facing the same issue, is there a way or a work around to achive this behaviour
Hello Sreeram,
To the best of my knowledge, this is not supported, as you have only couple of options - near, far or both. If you want, you can request that as a feature request on the link below:
http://devcenter.infragistics.com/Protected/RequestFeature.aspx
Hope this helps.
