815
Problems with generic cells
Hello again,
Ok, so i have the following problem:
I have a xamdatagrid linked to a datatable that is dynamically created. I store the index of some columns and after that, depending on the value of each cell, I insert a picture.
I have the following code and trigger, pretty simple:
  private void dg_InitializeRecord(object sender, InitializeRecordEventArgs e)
            e.Record.FieldLayout.Fields[myDynamicIndex].Settings.CellValuePresenterStyle = dg.FindResource("st") as Style;
<ControlTemplate.Triggers>
                                    <DataTrigger Binding="{Binding Path=Cells[ ? MY PROBLEM ? ].Value, Mode=OneWay}" Value="1">
                                        <Setter Property="Visibility" TargetName="green" Value="Hidden"/>
                                        <Setter Property="Visibility" TargetName="red" Value="Visible"/>
                                    </DataTrigger>
 </ControlTemplate.Triggers>
As you can see, i cannot get the index of the cell in xaml, as it is dynamically set in my .cs code. I tried the following but it didn't work
Binding="{Binding Value,
RelativeSource={RelativeSource AncestorType={x:Type igDP:Cell}}}"
Can anyone help?
