I am trying to programmatically set the ItemsSource property of a xamCarouselListBox using the code as below and although I see the rigthnumer of items in the list no item is databound. Here is a snippet:
With RelatedComponent.RelatedNavigationControl.DataCarousel
.ItemTemplate = myCarouselDataTemplate
.ItemsSource = Table.DefaultView
End With
I found no example of this in the XamFeatureBrowser solution
Thank you in advance
Alberto
Joe Dour"]I'm not sure what you mean by 'no item is databound'.
I think he meant nothing appeared in Listbox.
What you are doing looks reasonable. I'm not sure what you mean by 'no item is databound'.
