I am using a XamCarouselPanel with 3 items on a custom path. I have added different images (size 300x300) to each CarouselPanelItem. I have also set the following styling to try to get the images to fill the viewbox in the CarouselPanelItem Template but it doesn't work, only a small portion of the .jpg is visible (presumably the default ViewBox size). Any help is GREATLY appreciated. Here is the code:
<Style TargetType="{x:Type igWindows:CarouselPanelItem}">
<Setter Property="Template">
<Setter.Value>
<ControlTemplate TargetType="{x:Type igWindows:CarouselPanelItem}">
<Grid>
<Grid.RowDefinitions>
<RowDefinition Height="*"/>
</Grid.RowDefinitions>
<ScrollViewer x:Name="ScrollViewer" HorizontalScrollBarVisibility="Disabled" VerticalScrollBarVisibility="Disabled">
<Viewbox x:Name="ViewBox" HorizontalAlignment="Center" VerticalAlignment="Center" Width="300" Height="300">
<Grid x:Name="itemContentHolder">
<!--<Canvas x:Name="itemCanvas" Width="300" Height="300"/>-->
<ContentControl Margin="0,0,0,0" x:Name="itemContent" Content="{TemplateBinding Content}" ContentTemplate="{TemplateBinding ContentTemplate}"/>
</Grid>
</Viewbox>
</ScrollViewer>
<ControlTemplate.Triggers>
<MultiTrigger>
<MultiTrigger.Conditions>
<Condition Property="IsFirstItem" Value="True"/>
<Condition Property="IsListContinuous" Value="True"/>
</MultiTrigger.Conditions>
<Setter Property="Margin" TargetName="itemContent" Value="0,0,0,0"/>
</MultiTrigger>
<Condition Property="IsLastItem" Value="True"/>
<Trigger Property="AutoScaleItemContentsToFit" Value="True">
<Setter Property="HorizontalScrollBarVisibility" TargetName="ScrollViewer" Value="Hidden"/>
<Setter Property="VerticalScrollBarVisibility" TargetName="ScrollViewer" Value="Hidden"/>
<Setter Property="Stretch" TargetName="ViewBox" Value="Uniform"/>
<Setter Property="StretchDirection" TargetName="ViewBox" Value="Both"/>
<Setter Property="Width" Value="300"/>
<Setter Property="Height" Value="300"/>
</Trigger>
</ControlTemplate.Triggers>
</ControlTemplate>
</Setter.Value>
</Setter>
</Style>
Thanks for the help. I was missing the ItemSize parameter in the CarouselViewSettings.
I tried putting a 300x300 image into a xamCarouselPanel whose ItemSize was set to 300x300 and it seems to show correctly. Do you have a sample demonstrating the problem you are having? Note, you shouldn't need to retemplate the CarouselPanelItem. e.g.
