1090
Binding an int to the value of a XamNumericEditor
Hey,
I have a few questions related to the XamNumericEditor:
When I first tried binding an int to the XamNumericEditor I got the following error in the output:
System.Windows.Data Error: 22 : Cannot convert '1' from type 'Double' to type 'System.Int32' for 'en-US' culture with default conversions; consider using Converter property of Binding. NotSupportedException:'System.NotSupportedException: Int32Converter cannot convert from System.Double.
   at System.ComponentModel.TypeConverter.GetConvertFromException(Object value)
   at System.ComponentModel.BaseNumberConverter.ConvertFrom(ITypeDescriptorContext context, CultureInfo culture, Object value)
   at MS.Internal.Data.DefaultValueConverter.ConvertHelper(Object o, Type destinationType, DependencyObject targetElement, CultureInfo culture, Boolean isForward)'
This goes away if I set the ValueType property to Int32.  My question is: do I have to set ValueType or is it possible to have it automatically determined?
Also, when I completely clear the text in the XamNumericEditor (with ValueType=Int32), it does not set 0 in the underlying property.  So, it looks like the value is empty, but it is still there.  What is the best way to get around this?
