Seems pretty simple, but I can't find anything in the documentation or in these forums. Can someone please help?
I am not quite sure whether this would throw exceptions, depending on where you click.
EventManager.RegisterClassHandler(typeof(DataRecordPresenter), DataRecordPresenter.MouseDoubleClickEvent, new MouseButtonEventHandler(dr_MouseDoubleClick));
void dr_MouseDoubleClick(object sender, System.Windows.Input.MouseButtonEventArgs e){MessageBox.Show(sender.ToString() + "was doubleclicked");}
We do this a lot in our apps. Basically add something like this to your window constructor:
DataGrid.MouseDoubleClick += new MouseButtonEventHandler(DataGridOnMouseDoubleClick);
Replace "DataGrid" with the name of your XamDataGrid.
Then, you just need to write the event handler with something like this:
private void DataGridOnMouseDoubleClick(Object sender, RoutedEventArgs e)
DataRecord activeRecord = (DataGrid.ActiveRecord as DataRecord);
if ((activeRecord != null) && (!activeRecord.IsAddRecord))
....some stuff here with activeRecord
You would actually have to register an EventHandler for the DataRecordPresenter with the EventManager.RegisterClassHandler method.
Please follow the link below to see an example using the EventManager.
http://forums.infragistics.com/forums/p/20190/72920.aspx#72920
Hope this helps.
Let me know if you have any questions on this.
Alex.
