1255
MenuTool error when XamRibbon.Theme property is set
When I set my XamRibbon.Theme to any theme, I get the following error when I click the bottom split of a MenuTool that is set to ButtonType=Segmented.  If I do not set the XamRibbon.Theme, the MenuTool works as expected.
Interesting note that a Segmented MenuTool in the ApplicationMenu on the same ribbon works with the Theme!
Can anyone suggest how to fix this?
Extended Properties: InternalProcessName - at Infragistics.Windows.Ribbon.PopupOwnerProxy.OnOpen()
at Infragistics.Windows.Ribbon.MenuToolBase.OnIsOpenChanged(DependencyObject target, DependencyPropertyChangedEventArgs e)
at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at Infragistics.Windows.Ribbon.MenuToolBase.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at Infragistics.Windows.Ribbon.MenuTool.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args)
at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, OperationType operationType)
at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, OperationType operationType, Boolean isInternal)
at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value)
at MS.Internal.Data.PropertyPathWorker.SetValue(Object item, Object value)
at MS.Internal.Data.ClrBindingWorker.UpdateValue(Object value)
at System.Windows.Data.BindingExpression.UpdateSource(Object value)
at System.Windows.Data.BindingExpressionBase.UpdateValue()
at System.Windows.Data.BindingExpression.Update(Boolean synchronous)
at System.Windows.Data.BindingExpressionBase.Dirty()
at System.Windows.Data.BindingExpression.SetValue(DependencyObject d, DependencyProperty dp, Object value)
at Infragistics.Windows.Ribbon.DropDownToggle.set_IsDroppedDown(Boolean value)
at Infragistics.Windows.Ribbon.DropDownToggle.ProcessMouseDown(MouseButtonEventArgs e)
at Infragistics.Windows.Ribbon.DropDownToggle.OnMouseLeftButtonDown(MouseButtonEventArgs e)
at System.Windows.UIElement.OnMouseLeftButtonDownThunk(Object sender, MouseButtonEventArgs e)
at System.Windows.Input.MouseButtonEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget)
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
at System.Windows.UIElement.CrackMouseButtonEventAndReRaiseEvent(DependencyObject sender, MouseButtonEventArgs e)
at System.Windows.UIElement.OnMouseDownThunk(Object sender, MouseButtonEventArgs e)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.ContentElement.RaiseEvent(RoutedEventArgs args, Boolean trusted)
at System.Windows.Input.InputManager.ProcessStagingArea()
at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Boolean isSingleParameter)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler)
InternalSeverity - Error
InternalSource - Infragistics3.Wpf.Ribbon.v8.2
InternalComment -
