1564
Equivalent of DataTemplate ?
With the listview I can use the DataTemplate in order to choose which image I want to display.
 The datatemplate test some attributes of my "binding" item and then choose an image to display.
How can I do this with xamDataGrid please ?
Like this :
    <DataTemplate x:Key="IsPlayingGraphic">
        <StackPanel>
            <Control x:Name="icon" Template="{StaticResource playingImage}" />
        </StackPanel>
        <DataTemplate.Triggers>
            <DataTrigger Binding="{Binding Path=IsPlaying}" Value="True" >
                <Setter TargetName="icon" Property="Template" Value="{StaticResource playingImage}"/>
            </DataTrigger>
            <DataTrigger Binding="{Binding Path=IsPlaying}" Value="False" >
                <Setter TargetName="icon" Property="Template" Value="{StaticResource notPlayingImage}" />
            </DataTrigger>
        </DataTemplate.Triggers>
    </DataTemplate>
<GridViewColumn Header="" CellTemplate="{StaticResource IsPlayingGraphic}" Width="20"/>
Parents
No Data
Reply
  • 4850
    The CellValuePresenter is derived from ContentControl which exposes a ContentTemplate property so you can create a style for CellValuePresenter that has a setter for this property.
    There is a CellValuePresenterStyle property off the FieldSettings object that can be set for all field's in the grid by setting xamdataGrid1.FieldSettings.CellValuePresenterStyle = ... or for an individual field via the Field.Settings.CellValuePresenterStyle property.
    I hope this helps.
Children
No Data
